Limp Mode Only 2Nd Gear But Its Not A Faulty Gearbox
tmtmusic
I hope there is someone out there as this has been driving me crazy for over a year
First I will try to describe what is happening
First thing in the morning I can drive for around 20mins or until the temperature gauge gets to just above 1/3 then a little shudder and straight into limp mode , turn it off and on again can drive a little further until limp mode comes back , but on very cold days and motorways it may never happen.
The engine light is on a lot of the time but has gone off again normally when its very cold , if I pull away hard it will usually go straight into limp mode regardless off engine temperature
These events have never changed with every repair i have done.
This is what i have done to try and cure it in order over the last year
Fluid change ATF+4
Solenoid pack cleaned filter change and gasket
New 95amp battery
Fluid change and new filter ATF+4
New Transmission radiator
Earth bonded Gearbox
New Transmission brain
New input and output speed sensors
Then New complete Transmission box, and Torque converter
Fluid change ATF+4
New Cam shaft sensor
New Glow plugs
New EGR valve
New EGR solenoid
I have checked as much as possible wiring looms for continuity and breaks
And one final issue that may or may not be connected is the interior heater never really gets that hot
When i retrieve error codes i get
0403
0100
0110
0380
0340
and in the last few weeks now have
0520
0480
0645
Please help !!!!
hi looking through my code book all your codes relate to circuit malfunctions
have you checked loom is connected to your ecu correctly
also check for moisture at the connecters where they meet ecu
i have v6 petrol my ecu sits behind nearside headlight and next to my battery
had fault in my loom had to take connecters off ecu
moisture can get inside and corrode pins
dont where your ecu is on diesels
hopes this helps
Hi
I had a similar problem with my 57 gv 2.8crd, so took it to chrysler main dealer as local garage tried everything they could think of with no cure.
car was put on their diagnostics machine & straight away identified the problem to be the gearbox control module relay part cost £90 + vat + fitting  & about 20mins to change problem fixed.
According to chrysler the relay was jamming open inside & causing the car to go in to limpmode once the car was warm & when the car cooled down the relay would close taking limpmode off until it got warm again.
Hope this helps.
