  1. Past hour
  2. Earlier
  3. Hiya Pal! Yeah it's grating when they couldn't be arsed to say thanks, or confirm the help did, or didn't, work, REALLY rankles me. And when people used to pop up, no introduction, just straight into a question with an "I'm entitled to an answer" attitude, that pissed me off too. We don't have the Grand Voyager anymore, finally had enough of the mither, and got a Toyota Vellfire in November 2024. Anyway, good to hear from you, and hope you are well! Cheers, Nev
  4. Fiat Eper gives this page for the fuel tank https://eper.fiatforum.com/en/Drawings/Detail/L/L/Y/TK/102/0/10/0/SubGroup Then you can select from CC0.9 (TwinAir), CMBDS (diesel) or CC1.2. Petrol ones appear the same though I haven't looked at each part but the tanks are both 51839680, diesel being 51839686. Selecting 'GO' (& I've used the 0.9) brings you to this page https://eper.fiatforum.com/en/Cliche/Detail/L/L/Y/TK/102/0/10/0/SubGroup/51836520/1 Either way it seems parts are specific to the Ypsilon & the breather is part of the assembly so probably someone like 'ukchryslerspares' on ebay would be your best bet, they normally have a fair few being broken up
  5. I'm still about, keeping the Delta & Ypsilon gong. Even though they're not Chryslers! I've tried to help people explaining they're Lancias & to use Fiat Eper to get part numbers & stuff; never once had a thank you iirc. Shame the forum's so dead, but these 2 were never popular cars I suppose. Was a good Delta page on Arsebook which I think a few people migrated to, however I'm not on there anymore after being kicked off it in 2020
  6. i will take that!:rolleyes:
  7. had mechanic fit new EGR valve, anyway disaster struck when he broke housing, so he put new EGR valve into old housing, leading on now have fault code P403 have tried resetting codes, no good its still there, so thoughts please, is it possible EGR valve has been damaged? have read it can be that, so maybe mechanic has messed up valve ( he did offer to replace as his fault,and i said see how it goes,but MOT due soon and need to get it sorted, thanks in advance everyone pps is driving ok, so no fault in performance
  8. iam still here and check in regularly if i need a question answering, hi everyone!
  9. Hi , all hope i can find some help here . Ive had a few voyagers , generally great cars , i now have a gen 5 model . unfortunately i have an air con issue with it apparently one of the pipes that go into the compressor is leaking , so am after a diagram of some sort so my mechanic can show me which parts i need to order ( not too sure why he cant do this ) . Many thanks in advance . Andy
  10. Hi mate! Yup, gone are the days of regular activity! I did actually see a GV on the road last week, shocked me to bits! Any Chryslers seem to be rare as rocking horse muck now! I had a look on Autotrader and there's very few Voyagers for sale, but some people think they're worth a lot more than anyone in their right mind would pay for one! Hope you're keeping well!
  11. Hi Nev, The site appears as dead as my ex GV is. Only replying to this as an alert came up in my Inbox.
  12. Hi guys! Are there any of us still here? Though even we don't actually have a Chrysler any more!
  13. REAR CRASH BUMPER for a 2013 chrysler delta 1.6 multijet like new NOW FREE TO COLLECT FROM DN209DL see the previous post
  14. Hi, everyone I have a chrysler delta 2013 does anyone know where the BCM IS Ive been told its near your left foot under the drivers side ?? any help would be good Thanks
  15. Hi all, like many others I’m struggling to find a replacement part for my 2013 Ypsilon. I’ve got a fuel leak as the fuel tank breather pipe has split. Anyone any ideas where I can get either the pipe or a fuel tank with one attached. I’ve searched eBay and a number of breakers yards but no luck. The part number I have for the fuel tank is 25041231. Any help or suggestions appreciated. Doug
  16. Hi All, My 2008 Grand Voyager has the original REW radio unit, but there are a couple of problems - it will not copy CDs onto the hard disc, and MP3 files (of a valid sample rate) will copy, but will not play. I've replaced the HDD, but this has not helped. I also suspect a transient CanBus communications issue. I have considered a complete upgrade to something like a Kenwood head unit, but that seems be be a decidedly non-trivial process with many, many interconnect challenges. So here's the question: does anyone know if a more recent RHW (NTG4 Refresh) unit will function in a 2008 car, and is it plug-compatible? If so, this would be my preferred, lowest impact route. Cheers, Vince
  17. Hi . My clutch feels very soft and I am having trouble getting gears. Can anybody tell me where I can top up the clutch fluid .I have search the Internet and every answer says there is the top up near the brake top up reservoir but my vehicle don't seem to have a clutch reservoir that I can see . Can anybody help . Thank you in anticipation
  18. Hi, I have a leak in the small, U shaped hose from the water pump. (Pg 7-24 fig. 11, water pump CRD supplement) It isn't called anything specific and does'nt seem to have a part number. It is the hose just above the number 4, I have marked it with a red arrow. Anyone out there that can help??? TIA and regards
  19. Hi both my key fobs wont operate the central locking although i have no problems starting the car. I have tried removing the IOD main fuse and also taking the negative off the battery for 20 mins but no joy. I have had it on the diagnostics and received a few codes but not sure if these would relate to the central locking. B1A3C - internal siren battery B2128-16 - sensor supply voltage low Is there a receiver or control module i need to change or is it a dealer job, If so can anyone recommend a garage in the Leeds, west yorkshire area. Thanks
  20. I have a 2010, 300c Touring and a recent MOT advisory was the third ( high level ) brake light not working. The car brake lights are working. Does anyone know if this is on a separate fuse and if so what number. Does it operate from a relay? If it is a bulb does anyone know how to access it. I have scoured YouTube but nothing for the Touring. Any help would be most appreciated.
  21. I have a UK Chrysler Grand Voyager 2014 Is there any way to update the firmware and Maps for the UK please I struggle to find firmwere to update it as these vehicles are no longer in the UK and my VIN number is not recognised on any of the website websites Please Advise regards Brian Figg
  22. I have not been back to this thread for a while but thought I would update it in case anyone else is having problems. First of yes, the gaiter was for the handbrake cable so I was worrying over nothing there. Handbrake works just fine by the way. That clunking noise when changing gear wasn't anything serious. It was a gearbox mount which I had replaced and there have been no problems since, other than the "normal" querkyness of these semi auto boxes. I found that it was a bit of a learning curve but once you get used to it you can drive fairly smoothly. The oil pressure thing, no one seems to be able to find out what it is. It doesn't happen when the weather is warm but if the temps drop below 5 deg C that is when it happens. Although not all the time so I am thinking it must be a sensor. I do check the oil and it is fine, no drop in level since I last mentioned it. So apart from the odd rattles and you get from these cars because of the firmer ride everything has been good.
  23. Marketing the Delta & Ypsilon in RHD as Chryslers was a bloody disgrace. Still, for whatever reason Sergio Marchionne was on a mission to destroy Lancia & I'm sure this fitted perfectly with his ideas. Thank heavens we've new man at the Lancia helm; he says all the right things about the brand though they seem adamant that Lancia will be EV only & it doesn't look like they're coming back to the UK. Hopefully they will decide to come back & give up on the EV nonsense as well, but who knows.
  24. Not many Chrysler owners at all come to it.
  25. Thanks DeltaMike, that was really useful. Finding the specific part numbers quoted is difficult but went with shop4parts and went with the supplex and quoted for the Bravo 2007* which seemed to match specs on the part number. what turned up were KYB flex picture attached.y local mechanic fitted and the ride height looks good. The previous springs were 2 inches too short. Therefore either these were rear springs or the wrong part incorrectly sent. Hope this helps others. Not many details owners left now :( IMG_2030.heic
  26. Hi all, I'm hoping someone can help. I have a 2007 Chrysler Voyager 2.8d. The average and current fuel consumption figures displayed on the roof console is seriously incorrect. give me figures of 2.6 l per 100 km. interesting though is that the kilometers left to travel is always fairly accurate. Can anyone help me resolve this problem? Thank you Andy
