- Past hour
Hi @RichardM Well it's 2 months in, and so far loving the new motor! We've not done too many miles, but it is jolly well very, very, nearly as comfortable on a 120 mile run as the Voyager, but smoother, quieter, and more powerful, with very similar handling, and even more spacious! A new toy for me to buy trinkets for!
