- Past hour
Rubenges joined the community
TomC71 reacted to an answer to a question:
2006 2.8 Crd Grand Voyager Suddenly Lost Its Water!
lessuth started following 2012 2.8CRD leaking welch plugs
I'm having trouble sourcing a set of welch plugs for my 2.8. Can anyone help me with the size plugs I need? Cheers
Is anyone still here?
P0402 EGR Flow
P0402 EGR Flow
I have not been back to this thread for a while but thought I would update it in case anyone else is having problems. First of yes, the gaiter was for the handbrake cable so I was worrying over nothing there. Handbrake works just fine by the way. That clunking noise when changing gear wasn't anything serious. It was a gearbox mount which I had replaced and there have been no problems since, other than the "normal" querkyness of these semi auto boxes. I found that it was a bit of a learning curve but once you get used to it you can drive fairly smoothly. The oil pressure thing, no one seems to be able to find out what it is. It doesn't happen when the weather is warm but if the temps drop below 5 deg C that is when it happens. Although not all the time so I am thinking it must be a sensor. I do check the oil and it is fine, no drop in level since I last mentioned it. So apart from the odd rattles and you get from these cars because of the firmer ride everything has been good.
