  1. Past hour
  2. Hi, everyone I have a chrysler delta 2013 does anyone know where the BCM IS Ive been told its near your left foot under the drivers side ?? any help would be good Thanks
  3. Earlier
  4. Hi all, like many others I’m struggling to find a replacement part for my 2013 Ypsilon. I’ve got a fuel leak as the fuel tank breather pipe has split. Anyone any ideas where I can get either the pipe or a fuel tank with one attached. I’ve searched eBay and a number of breakers yards but no luck. The part number I have for the fuel tank is 25041231. Any help or suggestions appreciated. Doug
  5. Hi All, My 2008 Grand Voyager has the original REW radio unit, but there are a couple of problems - it will not copy CDs onto the hard disc, and MP3 files (of a valid sample rate) will copy, but will not play. I've replaced the HDD, but this has not helped. I also suspect a transient CanBus communications issue. I have considered a complete upgrade to something like a Kenwood head unit, but that seems be be a decidedly non-trivial process with many, many interconnect challenges. So here's the question: does anyone know if a more recent RHW (NTG4 Refresh) unit will function in a 2008 car, and is it plug-compatible? If so, this would be my preferred, lowest impact route. Cheers, Vince
  6. Hi . My clutch feels very soft and I am having trouble getting gears. Can anybody tell me where I can top up the clutch fluid .I have search the Internet and every answer says there is the top up near the brake top up reservoir but my vehicle don't seem to have a clutch reservoir that I can see . Can anybody help . Thank you in anticipation
  7. Hi, I have a leak in the small, U shaped hose from the water pump. (Pg 7-24 fig. 11, water pump CRD supplement) It isn't called anything specific and does'nt seem to have a part number. It is the hose just above the number 4, I have marked it with a red arrow. Anyone out there that can help??? TIA and regards
  8. Hi both my key fobs wont operate the central locking although i have no problems starting the car. I have tried removing the IOD main fuse and also taking the negative off the battery for 20 mins but no joy. I have had it on the diagnostics and received a few codes but not sure if these would relate to the central locking. B1A3C - internal siren battery B2128-16 - sensor supply voltage low Is there a receiver or control module i need to change or is it a dealer job, If so can anyone recommend a garage in the Leeds, west yorkshire area. Thanks
  9. I have a 2010, 300c Touring and a recent MOT advisory was the third ( high level ) brake light not working. The car brake lights are working. Does anyone know if this is on a separate fuse and if so what number. Does it operate from a relay? If it is a bulb does anyone know how to access it. I have scoured YouTube but nothing for the Touring. Any help would be most appreciated.
  10. I have a UK Chrysler Grand Voyager 2014 Is there any way to update the firmware and Maps for the UK please I struggle to find firmwere to update it as these vehicles are no longer in the UK and my VIN number is not recognised on any of the website websites Please Advise regards Brian Figg
  11. I have not been back to this thread for a while but thought I would update it in case anyone else is having problems. First of yes, the gaiter was for the handbrake cable so I was worrying over nothing there. Handbrake works just fine by the way. That clunking noise when changing gear wasn't anything serious. It was a gearbox mount which I had replaced and there have been no problems since, other than the "normal" querkyness of these semi auto boxes. I found that it was a bit of a learning curve but once you get used to it you can drive fairly smoothly. The oil pressure thing, no one seems to be able to find out what it is. It doesn't happen when the weather is warm but if the temps drop below 5 deg C that is when it happens. Although not all the time so I am thinking it must be a sensor. I do check the oil and it is fine, no drop in level since I last mentioned it. So apart from the odd rattles and you get from these cars because of the firmer ride everything has been good.
  12. Marketing the Delta & Ypsilon in RHD as Chryslers was a bloody disgrace. Still, for whatever reason Sergio Marchionne was on a mission to destroy Lancia & I'm sure this fitted perfectly with his ideas. Thank heavens we've new man at the Lancia helm; he says all the right things about the brand though they seem adamant that Lancia will be EV only & it doesn't look like they're coming back to the UK. Hopefully they will decide to come back & give up on the EV nonsense as well, but who knows.
  13. Not many Chrysler owners at all come to it.
  14. Thanks DeltaMike, that was really useful. Finding the specific part numbers quoted is difficult but went with shop4parts and went with the supplex and quoted for the Bravo 2007* which seemed to match specs on the part number. what turned up were KYB flex picture attached.y local mechanic fitted and the ride height looks good. The previous springs were 2 inches too short. Therefore either these were rear springs or the wrong part incorrectly sent. Hope this helps others. Not many details owners left now :( IMG_2030.heic
  15. Hi all, I'm hoping someone can help. I have a 2007 Chrysler Voyager 2.8d. The average and current fuel consumption figures displayed on the roof console is seriously incorrect. give me figures of 2.6 l per 100 km. interesting though is that the kilometers left to travel is always fairly accurate. Can anyone help me resolve this problem? Thank you Andy
  16. Did you ever resolve? Mines doing the same now
  17. I have used RockAuto.com in the US for Chrysler parts. Their prices are far better than UK prices (assuming you can even find the part you need in the UK) and their shipping is scarily fast. You have to look for Chrysler Town & Country parts, but they are exactly the same as the UK Grand Voyager. My latest RockAuto purchase was a Brake Fluid level sensor for my 2008 Grand Voyager. Ordered on Saturday, arrived Wednesday. Not bad! Cheers, Vince
  18. Hi All, I have recently part-exed my 2006 Grand Voyager for a 2008 Gen 5 version. One thing the Gen 4 car did was chirp the security siren when you locked the car with a door still open. I found that the 2008 car does not do the same so I started digging to see whether this was normal behaviour or something was wrong. I scanned the fault codes and discovered the ITM module is reporting a U110D code, which says it has lost communication with the security siren. So here's the question - does anyone know where the siren is located? I think it is just below the passenger-side headlamp unit, and you need to take off the front bumper cover to get to it. If someone can confirm this, or has experienced the same problem I would be very keen to hear from you. Cheers, Vince
  19. Anyone had the same problem - orange lights above door mirror don't go out after locking. I assume these will drain battery!
  20. Hi All, I have just purchased a 2008 Chrysler Grand Voyager Limited. I have been a Grand Voyager owner since 2001, but this is my first 5th Generation car. I have two minor head-scratching issues which I am struggling to understand. One - the TPMS tyre pressure display on the dashboard is showing in Bar, rather than PSI, but I cannot find the way to change it to PSI. It is not affected by changing the Personal Settings units from Metric to U.S. Two - when I set the display units to U.S., the interior climate display changes to Fahrenheit OK, and things like distance to empty show in miles as expected, but the outside temperature display on the dash (next to the compass direction) remains in Centigrade. I can't find anything relevant in the handbook, so does anyone have any thoughts or solutions? Many thanks, Cheers, Vince
  21. alfaspud
    Rain leak
  22. Okay I’ve sorted it myself. Unbelievably it was a Bluetooth unit plugged into the cigarette lighter beside the ashtray, remember them. Spent hours running through what had been replaced that may affect the TPMS display and other associated features and finally came down to what I thought was madder than a bucket of frogs! A new BT unit for the phone. Removed it and instantly all the dash fault lights went out and as long as I don’t have it plugged in all is fine. Oh well, back to the earbuds I suppose.
  23. Hi All Happy New Year. I firstly want to thank you for all your help. I have done the Thermostat-into-the-hose mod and the temperature resistor mod for the charging circuit and I managed to find a complex parasitic battery leak problem, all using your excellent forum and I couldn't be more grateful!!! All this as a non-mechanic! Anyway... I am having to spray 'easy start' into my Voyager to get it to start. I'm too afraid to to remove the Glow Plugs in case I snap them off or something. -Not an accomplished car maintenance person. Anyway.. I remove this little black cap and spray into the hole. It's kinda half blocked and I wondered what it's for and if I should be doing it....?
  24. Hi @RichardM Well it's 2 months in, and so far loving the new motor! We've not done too many miles, but it is jolly well very, very, nearly as comfortable on a 120 mile run as the Voyager, but smoother, quieter, and more powerful, with very similar handling, and even more spacious! A new toy for me to buy trinkets for!
  25. Hi Anybody know of or experienced the following issue with the TPMS display on a 2006/7 or older 300C The issue: Turn the car on go into systems and car display showing all four tyre pressure levels. All pressures showing as per normal for the size of tyre. Drive a few miles and the nearside left display disappears and the warning chime and light start going off. Drive a few more miles and one by one they all go out and the chime starts to drive you mad. Stop the car, turn the ignition off, restart the engine and all four tyre displays are back as per normal. Drive a few miles and the whole process begins again. I’ve checked all the batteries in the TPMS units with a scanner and all are good. I do have, if the readings can be trusted, a very slow leak on the near side rear but re-inflating to correct level has no beneficial effect and the problem described above continues. I assume it could be a receiver issue rather than a TPMS sender issue ? But if so, can you even get/buy the module, which I’m told sits behind the dash near the ignition switch/key, not checked that yet but thats what I've been told. I’ve also been told it's possible to disable the damn system with something called a ‘Star Reader” whatever that might be. No work has been done to the car recently in relation to tyres, I did replace all of the glow plugs a few weeks ago but cant imagine they would, in any way, have an effect on the TPMS system! But stranger things happen at sea and all that. Any help would be great.
  26. Looking on eper, there is a fair choice of springs across all variants & we didn't get all of them in the UK. Specifically the 1.8 twin turbo & I don't think any with damper control (I assume that's Skyhook). It takes a bit of deciphering but I think the plus sign in the options means with (obvs), the exclamation mark means without. I don't know your car or what springs you fitted (mine is a 1.4 MA SR & I fitted 1.4 Bravo rears & they made no difference, but I haven't had to do a front yet) but I suppose it is possible to affect the ride height on the strength / length of the spring. Say if you had a heavier 2.0 diesel car but fitted the 120hp petrol springs. I remember from my amateur motorsport days, if a version was available diesel springs & components were often a simple way to beef up a 'standard' car for rough stuff, extra ride height & durability etc. I have lost ride height on other cars with broken springs, damaged lower spring platforms & knackered top mounts but you say all your items are good. Have a look at this link & see if you can decipher which springs you should have. Part number 12 obviously, hover over the circled 'i' and you should see the applications. If you click on a part number, then the 'drawings; word on the next page it will tell you if it's shared with anything else Fiat / Lancia / Alfa. For instance, part number 5 (top pad) is Stilo, Bravo II & Delta. https://eper.fiatforum.com/en/Drawings/Detail/L/L/DEL/TN/443/1/20/0/SubSubGroup
