			chrysler grand voyager left hand drive shaft with abs part help! majicmanda reacted to an answer to a question:
			How do I reset the oil service warning? majicmanda reacted to an answer to a question:
			P0402 EGR Flow majicmanda reacted to an answer to a question:
			P0402 EGR Flow
			P0402 EGR Flow
			Delta 1.6 MJ Multiple Issues. Maybe I bought a lemon? hazeywood reacted to an answer to a question:
	Delta 1.6 MJ Multiple Issues. Maybe I bought a lemon?hazeywood replied to hazeywood's question in Chrysler Delta I have not been back to this thread for a while but thought I would update it in case anyone else is having problems. First of yes, the gaiter was for the handbrake cable so I was worrying over nothing there. Handbrake works just fine by the way. That clunking noise when changing gear wasn't anything serious. It was a gearbox mount which I had replaced and there have been no problems since, other than the "normal" querkyness of these semi auto boxes. I found that it was a bit of a learning curve but once you get used to it you can drive fairly smoothly. The oil pressure thing, no one seems to be able to find out what it is. It doesn't happen when the weather is warm but if the temps drop below 5 deg C that is when it happens. Although not all the time so I am thinking it must be a sensor. I do check the oil and it is fine, no drop in level since I last mentioned it. So apart from the odd rattles and you get from these cars because of the firmer ride everything has been good.
			Coil Springs Too Low bignev reacted to an answer to a question:
