Day Running Lights
Dazandtrace
8 answers to this question
dont know
i connected mine to a ignition feed and have them turn off when the side lights come on
as the ones i got had i third wire thats turns them off when a + feed is on the wire
Hi
This is what I am also trying to do. Exactly how did you connect to ignition feed please so I can do the same and also to th3nside lights
i tested the fused feeds to see which one was live when engine started and dead when key on acc
rear blower fuse 25 on its own next to the big green fuses and the relays
took a feed from that
that set lights i have have a third wire that when feed with + will turn off the drls i connected to my sides
so my drl only work when no other lights are turned on
