Hello . I've just bought a 2.8 crd 08 plate . When I went to look at it the seller was charging the battery , story was " hasn't been used for a few weeks" anyway I noticed the boot ( rear hatch ) kept on opening . Beep beep then opening and closing by itself . Thought ok it's the flat battery or a dodgy key fob. Took it home , it started fine , drove fine , but when I got up the next morning , boot was wide open and battery was totally flat , inside lights would have drained battery . Took battery out . Charged it overnight, fitted it , and hatchback opens up and closes on it's own again . Took key fob battery out , and it still does it . Looks like I'm going to have to disconnect hatchback electrics , or is there a cure .
Also rear park assist , I have 4 lights on all the time . Plus auto gear indication . PRND3L. All the lights light up , and eventually the correct one stays on .
Foggy
Thanks in advance for any help . Cheers des
9 answers to this question
