Engine problem 2.8 crd
EasyPcc
On 2/19/2023 at 10:25 PM, bignev said:
Would you like to explain what your problem is, as I'm not too happy clicking on links posted by a first time poster.
Not that I have a diesel anyway.
Hi, I have the same issue with my GV 2008 Mk5 2.8 CRD, no one seems to know how to fix it, I have changed the MAF sensor, the EGR valve and the throttle body, I have taken out the injectors and had them tested, they were all good, still have the same issue.
I hope you found solution,  if so please post how. Regards, Ken.
Witam, mam ten sam problem z moim GV 2008 Mk5 2.8 CRD, nikt nie wie jak to naprawić, wymieniłem czujnik MAF, zawór EGR i przepustnicę, wyjąłem wtryskiwacze i sprawdziłem , wszystkie były dobre, nadal mają ten sam problem.
Mam nadzieję, że znalazłeś rozwiązanie. Jeśli tak, napisz, jak to zrobić. Pozdrawiam, Ken.
Edited by Kennyboy1962
correction
