Headlight Washers
marc1984
I've had my grand voyager v6 limited for almost 3 years and never realised till now it has headlight washers checked handbook and says with lights on use washes as normal,but nothing I've swapped relay with the horn one and horn works fine there's no noises or anything
Might also be worth trying them manually and see if you can release them (might have got stuck).
This is with the usual cautions, I found mine really difficult to lift so the spring is very strong! But I put my fingers around it and lifted it up a little, just enough to check it was free and could move. When you've done that, get somebody to watch them when you trigger them (as crispin says, put lights on, wipers and then a good long press on the trigger) and see if they move at all, or just move and don't squirt.
