Engine Warning Light & Stop Start
poopydog
Oh well, here goes:-
New clutch fitted, new timing belt/ water pump fitted, new plugs, oil filter etc fitted on Thursday 16th Jan.
Returned  on Monday 20th Jan running fine.
Wednesday 22nd Jan, morning start, a  little lumpy for 5-6 seconds then settled down, carried  on, 1 mile later engine warning light and stop start fail lit up.
Back to garage, running fine, reset diagnostics, checked Delta Forum -  see Josboogz entry approx 16 monthes ago. Exactly the same fault shown.
Running fine until Friday, 24th Jan, same thing happend but no lumpy running, switch engine off for 2 hours and everything reset  itself ( I thought you would need diagnostics kit to do this? anyway.....).
Saturday 25th my stop/start not having worked for about 3 plus years began to work of  its  own accord! worked 3 times  in a 20 minute window, 2 hrs later engine warning light and stop start fail lights lit up again.
TODAY SUNDAY 26TH JAN -  0840AM. Started as usual, NO warning  lights lit, lumpy running for 2/3 seconds, settled down to idle around 11/1200rpm. short excursion to 2000rpm then back to idle.
RUN FOR APPROX 2/3 MINS - ENGINE WARNING LIGHT AND STOP START LIGHTS  LIT !!!!!!!!!!!
Any ideas  please??????
N.B. Vehicle is back in the garage in FEB for new pads and discs ( due to an argument with that wonderful tyres and brakes company called ..CRAP FIT) and I hope, while  it is in this problem can be sorted.
P.S. Running  out  of money!!!!!
Thankyou
Thankyou, yes  it  is the multiair.
Firstly I have  just pooped.....
Secondly amazing  variations on price and model £78 to almost £600
Just to say today ran fine all day  but  its  not tomorrow yet...
why does it fail (if  it has failed) a day after  having service  items replaced.
Worse case as you suggested:- replacement  part No?    from where? as the engine is a Fiat unit would a main dealer be the best bet?    specialist in multi air engines somewhere  in the uk?    second  hand parts  if available?    repair  if available?
or as I am in no hurry to change the vehicle, run with it?     possible harm by running short/long term?.
What oil was used? Selenia energy K is the recommended oil and does work well, there is also a little oil filter in the head that may be choked, it is under the timing cover at the back of the head
Thanks Andrew, the vehicle is booked in on Feb 7th for the last few jobbies to be completed. I shall ask for some time to be set aside to check out these possibilities. As for the  oil I have used Petronas Syntium 300 AV 5W-40. This has been used since 28,000 miles service. I did a little research into various  oils a while back and this seemed to be a direct equivalent. Please tell me  if anyone  know otherwise .
Hows about engine being overfilled with oil?
Probably wouldn't help!
With a filter change, 1980s and 90s fiat's used to be 4 (litres) and feck it, when refilling, my wife's 1st Punto (01) took less than 3 litres and her subsequent Bravo and Delta are a little more than 3 litre fills.
Overfilled, you could have the block/head drain pipe sitting in oil
