Washer Pump
Ihavenoclueaboutcars
Hi all could someone help me out, I'm after a washer pump for a 2013 Chrysler delta m-air, is there any other compatible ones that could be used if I can't find one from a Chrysler delta?? Anyone had the issue of the washer pump giving up the ghost and only squirting water on the windscreen when stopped and not whilst driving? Not very good with cars so this is head work to me
I'm not sure of the correct part NO for the Delta but assuming it is the same a Stilo it is the same part for any Fiat Group product from Alfas to Lancias etc
https://www.shop4parts.co.uk/?name=store&op=Results&keywords=S4P2391
that said, is it not more likely a problem with the stalk or wiring somewhere as the pump is only does what it is told, it will only work if supplied with power, so what is doing that????
eper shows the Delta shares the same Pump with the Bravo (as per alot of things!)
71748810 ELECTROPUMP
Famiglia: FE17 - WINDSCREEN WASHER-ELECTROPUMP
Availability: Product that can be ordered Minimum quantity per package: 1
Macro-family: M Discount code: M
Weight (grams): 98 Listed price(1): 40,88 EUR
Measurement unit: Num Price including taxes: 49,87 EUR
FIAT - 3L NUOVA BRAVO (2007-2009)
55514/00 - WINDSCREEN WIPER
FIAT - 3Y NUOVA BRAVO MY 2010 (2010-2014)
LANCIA - TN LANCIA DELTA MY 2011 (2011-2014)
LANCIA - TH NUOVA DELTA 844 (2008-2011)
Though as Mikey says and as posted on here some time ago - check the hose off the top of the reservoir - has a habit of coming off
Edited by Nello
