karmannski Posted November 13, 2017 Report Share Posted November 13, 2017 It has happen 3 times I few weeks when I drive of and the engine stops No faulty codes It also struggles to start in the morning Help Quote Link to comment Share on other sites More sharing options...
0 andyb2000 Posted November 14, 2017 Report Share Posted November 14, 2017 Hi Karmannski,That's tricky as we've not got a lot to go on! But, by the sounds of it now it's cutting out the suspicion is the pressure relief valve failure that's quite a common one doing the rounds at the moment!Take a look at by our old pal Daz and see if you can do the same test. Replacing the valve is tricky as there are a few part numbers circulating so if you go to replace check closely the part you're replacing is an exact match (Some aren't exact thread size as a few people I've spoken to recently found out and kindly passed the info onto me). Also, struggling to start on a morning could also be glow plugs, so time to test and perhaps replace:https://www.youtube.com/watch?v=2vtGGp4Jqp8&t=8s gordy 1 Quote Link to comment Share on other sites More sharing options...
0 karmannski Posted November 14, 2017 Author Report Share Posted November 14, 2017 Got all new glow plugs But tell me what Daz is actually trying to show on this video ? I'm I that thick ? I don't get it. Floyd the fuel go faster or not at all ? Quote Link to comment Share on other sites More sharing options...
0 andyb2000 Posted November 15, 2017 Report Share Posted November 15, 2017 OK, if new glow plugs then more likely this fault shown on the video.Daz is showing that you get fuel out of the pressure relief valve. You should get NO fuel out of there under normal conditions. So, take plastic hose off the pressure relief valve. Plug or block the pipe now dangling (the return fuel line). Put a small plastic pipe onto the pressure relief valve output and put to a small container (Make sure it's secure for when you start).Then start and run car a couple of minutes. See if any fuel. If there is, then you need to replace it. Hope that helps. Quote Link to comment Share on other sites More sharing options...
0 BigDaddy Posted December 13, 2017 Report Share Posted December 13, 2017 Hi. I'm new over of Voyager 2.8 CRD and I have the same problem recently. I checked that valve and petrol was going not from that place only from fuel line pulled out from it. As engine starts only when I put key in to ignition and start without waiting for glow plugs to warm up. Today on the way to work engine stops and it was a bit scary as I was overtaking a lorry on 3th lane. This my be the same problem? Quote Link to comment Share on other sites More sharing options...
0 mikebh8 Posted December 13, 2017 Report Share Posted December 13, 2017 Justvto clarify, you meant diesel jot petrol.Andyb2000 opened a topic about it, move there and you might get some more info. BigDaddy 1 Quote Link to comment Share on other sites More sharing options...
0 BigDaddy Posted December 13, 2017 Report Share Posted December 13, 2017 (edited) Yes diesel. Thanks Edited December 13, 2017 by BigDaddy Quote Link to comment Share on other sites More sharing options...
0 karmannski Posted December 13, 2017 Author Report Share Posted December 13, 2017 change your fuel filter and buy only good quality diesel. Since I have stopped buying Diesel from Murco and use only Shell or ESSO prblem gone. BigDaddy 1 Quote Link to comment Share on other sites More sharing options...
0 soupstone Posted December 13, 2017 Report Share Posted December 13, 2017 Had cutting out issues twice, on 2 different GV's, both times it was the fuel filter. Engine cuts out, ignition lights come on as you stop, sometimes it would restart immediately, sometimes it would take a few tries. BigDaddy 1 Quote Link to comment Share on other sites More sharing options...
0 BigDaddy Posted December 14, 2017 Report Share Posted December 14, 2017 (edited) Thanks guys, I try to change fuel filter over the weekend Edited December 14, 2017 by BigDaddy Quote Link to comment Share on other sites More sharing options...
0 BigDaddy Posted December 15, 2017 Report Share Posted December 15, 2017 just to make sure it's only one fuel filter under the car on tank bay ore there is second one somwere? I wanted to buy online and there are 2 options. Any recommendations to the filter manufacturer? Thanks Quote Link to comment Share on other sites More sharing options...
0 andyb2000 Posted December 15, 2017 Report Share Posted December 15, 2017 Just the one, it's location changes depending on model and year, so a physical check is a good idea.Mine is under, embedded in the fuel tank with the pump assembly, plastic outer casing. Take care when dealing with the plastic casing, it's prone to cracking and damaging easily. Quote Link to comment Share on other sites More sharing options...
0 BigDaddy Posted December 15, 2017 Report Share Posted December 15, 2017 There is one under like yours. Thanks Quote Link to comment Share on other sites More sharing options...
0 8953lewis Posted December 16, 2017 Report Share Posted December 16, 2017 Hi allBeen having similar issues with starting first thing then once warm an absolute pig to start. Tried 5 maybe 6 goes to get the engine to start until today and as many previous posts changed the fuel filter & hey presto starts first time every time old filter was clogged with what I can only describe as gunge also had the engine decarbonized & not sure yet if it makes a difference only time will tell. karmannski 1 Quote Link to comment Share on other sites More sharing options...
karmannski
No faulty codes
Help
13 answers to this question
