Voyager 2001 Heated Mirrors?
voyagernoob
Here bignev your telling me something new about a heated strip. Just had a look see, can't see anything, I've an LTD edition too. Bu**er better take it back and get a refund...Probably fitted wrong windscreen last time it got broken. Take note of that issue if window needs renewing they may ask, "heated or not heated sir". Come to think of it is it in wiring diagram.
As you say more than likely fitted the wrong version at a screen change sometime.
Yes it's ruddy useful too.
So they discontinued it on the facelift models.......cheers.
My old ones had it, new one doesn't.
Like the 2 ligths on the vanity mirrors, reduced to 1 on newer cars.
Or the really annoying one - backlit headlight switches on older cars - you guessed it, not on my 2005 facelift, or on the replacement unit I thought I was clever by ordering.
I did eventually sort out those last 2 "improvements" though by getting hold of older parts, and finally figuring how to wire the switches so the lights dim and brighten the right way with the rocker for dash light dimmer.
