Decarbonisation
macuniyanukukuk
Cold water hits hot piston and explodes carbon. Oil does not rust engine but water will. We are all cast block & alloy head high compression modern 4-stroke diesel engines these days, You would have to get those particles down to nano-sized to get them to pass through piston heads, rings, valves, and out through exhaust manifold, the cat and the whole exhaust.I don't want water in any part other than the cooling. Certainly if you did explode carbon - where is it going to go - have you thought this my friend ?
