Mr
Scouse
B&M module is shared across the range but you do need the correct part number.  Fiat EPER lists the up to date part as 51943247 & it is shared with the models as listed here (click on the word 'drawings'):
https://eper.fiatforum.com/Part/SearchPartByPartNumber?Language=en&PartNumber=51943247
You will need a proxy-alignment after to get the Canbus system to recognise the new unit, until you do that the mileage on the car will flash.  This can be done at a dealer, at an independent with access to Fiat's Multiecuscan software or you can buy a simple version of that and do it yourself https://www.multiecuscan.net/
Hope that helps
