Timing Belt Tools
Daz264
Hi guys im gona change my timing belt and water pump and fan belts . Iv been looking for the tools to hold every thing in place but theres so many and the sellers aint sure if its the right one for my gv.so are they all the same kits coz they look the same to me. I got a 2004 gv 2.8 crd auto diesel ...can u guys light the way for me plz lol
8 answers to this question
Hi. Been two years since I did mine but if remember right any of 2.5 /2.8 /ldv tools will work. Laser brand was made of better metal but thats about all.
Essentially there's three locking pins you need to get before removing timing belt. Two at top engine either side locking cam shafts. Each you'll need to locate screw plug to insert pin. The third you need to remove starter motor to see. If it's never been done you'll probably find yellow plastic plug in pin location point that needs removing. Third pin locks flywheel. Need to remove left top engine mount. Also might find you need new camshaft seals.
Edited by Alex
I got someone doing it for me this week so il just order 2 so he has everything he might need but thx alot. I got the new belt water pump and tentioner and the 2 new aux belts and 16 ltr of coolant and the belt kit so he shud have everything once the seals turn up. Thx alot for ur help alex
