not starting
jones
Hello again!
Well as I said on the other section, mine is petrol, but I had a Kia Sedona with a "wind over but not start" problem, and fine with a sniff of easy start, or other such spray! Mine was ultimately the injectors, but that seems to be a rarity on the Voyager.  More possible to be the fuel filter housing cracking, or the fuel pressure non return valve. But hopefully the diesel guys will be along soon to chip in with actual Chrysler experience!
Cheers, Nev
