Looking At Buying A 53 Plate With 124000 Miles Are There Any Things I Should Be Looking Out For?
Fcm2015
Hi I wonder if any one can offer me some advice on a car I have seen. are there any items I should pay attention  to when looking around the car. I am aware that the drives elec window is not working and also that the sliding door on the passenger side does not close when you use the key fob. other than that it looked like a good car?
you dont say what engine and model
the window could be that it needs new brushes in the motor you mite get away with just a clean it is a easy job to do
i sanded down a set of hoover brushes and have worked great for nearly a year so far
the door if it dosent work form the buttons as well at times
there is a wire carrier that looks like a chain these wires are for door motor and locking system one or more of these wires could be partly broken cut and add a new piece wire and replace theres plugs just behind seat belt cover and another on the door
if auto check that it goes smoothly into and out off each gear 3.3 does wine abit
parts ebay and euro parts are quite good
thanks for
thanks for the feed back it is an auto 3.3 v6?
i got 03 plate 3.3
i LPG it paying 16p per mile instead of 29p per mile on just petrol works really well ok cost £1000 to have fitted
but paid for it self in 9 months
unles you got service history to tell you when it was last done i would do all filters change including auto box filter and remember to only buy ATF+4 oil to go in it about £35 on ebay for 5lt
if you can afford it try and go for a 05 plate with stow and go seats but the 53 the middle seats will fit in the boot and will give you enough room to fit a 5 foot sofa inside without moving the rear bench seat
