Grand Voyager 2.8 Crd Exhaust Replacement
hacka1979
Hi everyone,
I have recently bought a 2007 GV which needs a little work doing.  One of things on my list is to completely replace the exhaust system as it looks in generally poor condition and the last 2 MOTs have noted an advisory about a front end exhaust gas leak.  Has anyone attempted this themselves and any advice on where to source the parts ?   I'm quite handy with a set of spanners but would be doing the work on my driveway at home so access will be limited.
Any advice greatly appreciated  :).
Adam
Hi, I didn't replace the exhaust but I replaced my engine and to do that I needed to disconnect the exhaust from the manifold.
That is the most difficult place to reach on the exhaust.
The car needs to be high up ( I used a friend's garage to lift the car up), you should get a set of decent stands.
You need a long (I used two) extension for the four 10mm bolts. They can break so apply wd40 first and leave it for a while to suck in
My advice if you want, replace the gasket and don't use any gasket sealant ( you probably know that already)
Hope it help.
Must add here as I've a spare exhaust hanging from my rafters in the loft, got it from Fleebay quite a few years ago as I had a few holes in one of the boxes. But as I said looked for an easy way out and bandage did the job. Maybe not next time though..
