2.5 Crd Lights Flickering Badly And Rough Idle
Slopey
Had this issue for a while now, lights flicker engine rough idles, battery dies overnight. I've changed the alternator and I have to pull the IOD fuse everyday, when I disconnect the auxiliary lead from the alternator it removes all the problems but obviously doesn't charge the battery. Are there any fixes for this issue as I've heard its a common problem.
Cheers all
