Hi All
lme121
2003 chrysler voyager 2.5 CRD manual 1400000 miles This cut out on boxing day with no warning try restart and will not crank over also no glow plug light on upper dash and can not hear diesel pump
Everything else works fine. Anyone had this problem can help thanks Graham
Oh bugger!
The red light is the immobiliser circuit, I guess you have tried leaving the key in the ignition position for 20 to 30 seconds for it to recognise it?
Do you have a spare key to try?
Also try the proverbial "switching it off and on again" attempt, battery negative lead off for 20 minutes or more, rather than just the fuse out, then see if it accepts the transponder in the key this time? You may need the radio code after this.
Oh and try posting this on the technical help section, most likely get the diesel drivers input too when it's spotted!
Edited by bignev
