12V Output
3ddesign
Thanks, The 12v outlet on the right hand works off the key, but the one on the left off the battery doesnt work at all. Do these cause bother in general ?
The lefthand one and the one in the boot are or should be permanent 'high output' live (bi-derectional) and direct wired directly to the battery. If you don't use them, they should not cause you any problems whatsoever.
1+3
