Brake Warning Light Illuminating Intermittently
Sentech
I know you say the fluid level is spot on, but is it at the top?
The warning light is also for low fluid, so if it's intermittent it may be moving fluid, just my thought but if it isn't already bring it up to max, and if the light coming on is "repeatable" under circumstances you know, then maybe fix the float up and drive it to see if it comes on at that.
Or is it the handbrake switch become loose? And moving and coming on when the lever is fully down?
