Engine management light
biggsy
I fitted a swirl valve bypass & found that the light does stay on. If you have a scanner or laptop software then you can turn it off.
Or simply, just disconnect the battery negative for 30 seconds (standard PCM reset time) & it will reset to it's parameters & the PCM will be fooled into thinking that the swirl valves are still connected ;)
