P1784 How Many Litres Of Atf+4 Do I Need?
vvv
My 147,000 mile 2001 3.3L Grand Voyager illuminated its check engine light yesterday. The DTC codes stored are P1784 and P0700.
I checked the fluid level when I got home with engine idling and transmission in park. The fluid level on the dipstick was low for the hot scale so I topped it up. Earlier in the day it was noticeably clunky shifting into and out of reverse. I put the battery on charge and was surprised to see that my Accumate charger thought it was quite flat. I guess it's had a lot of short journeys recently.
I have found a transmission fluid leak on side cover. The transmission is about due for its next filter and fluid change so I am going to drop the pan, change the filter, fit a new solenoid pack and new speed sensors. How much ATF+4 do I need to refill the transmission? I realise that some old fluid will still be left in the torque converter.
Where can I buy ATF+4 in the UK at a nice price?
I used Morris Multitrans MPC yesterday as I was out of ATF+4. What other ATF+4 compatible fluids are there in the UK?
Edited by vvv
Its £6.40 @ trade where I go local and exactly £7.59 retail delivered. All years manuals are here .
HIYa Steve Crees  - ! Select from here, the 2.8 [and 2.5] TURBO DIESEL diesel is here. You will find the head bolts at section > 9 - 16 ENGINE. Remember Chrysler say new cylinder head bolts must be used you will find the sequence in section > ENGINE 9 - 29
I couldn't find info on the transmission pan bolt torque in the FSM that I have so I'm posting it here in case someone else is looking for it. According to the instructions that came with my new Wix filter:-
Initial tightening to 80 inch pounds force (9 Nm)
Final tightening to 120 inch pounds force (13.6 Nm)
I eventually found the answer to my own question.
I need 3.5L to 4L of ATF+4 to drop the pan and do a filter change.
https://www.youtube.com/watch?v=-fFsLtHV4os
or...
I need 9L of ATF+4 to do the job properly and flush the old fluid.
https://www.youtube.com/watch?v=Vu4Q348-0rs
I guess I will buying another 5L pack of fluid today.
