Hi all, seeking some advice. I have a crack in a unit attached to the front right hand side of the engine. It is leaking water when cold and streams out when under pressure. Car obviously gets hot when the water level drops. I am assuming that his is a water pump? Attaching photo below. Any advice on what his unit is and how and where I can get a replacment.  Had he car for  2 years and not done much research on the car apart from it is a rebadged lancia delta. There was some mention that this also has same engine as a fiat Bravo? A quick info dump would also be good. Thanks in advance for your help!
