Delta Heater
Posted 17 February 2018 - 12:14 AM
Wondering if anyone has noticed this and can offer a solution???
Posted 17 February 2018 - 03:26 AM
I think I've commented on other threads Andrew I think the heater is a bit poor. I was spoilt by my old Coupe which had a heater like a hairdryer in minutes but its the direction and power of heat that I do not like. I never seem to be able to get the correct direction from the vents - I know the centre vents are fairly high but I like them to direct heat on to my hands this time of year which it never really does very well. Its either not there or aiming at my face. The output is a bit naff as well - not especially strong. Yes I have changed the pollen filter so not sure what else you could actually do to improve. I know Mikey had some issues with the flap which directs Air in to the footwells but mine appears to be working still ok though without much effect.................
Edited by Nello, 17 February 2018 - 03:27 AM.
Posted 17 February 2018 - 10:00 AM
Posted 20 February 2018 - 08:06 PM
Yeah defrosting the windows is pants.... I'd be better punching myself in the knackers and breathing hot air on the windows that way than the poxy fan under the dash...
My recirc motor failed on mine (quite common on Bravo's) and it's a dash out jobby and a new heater eek! Fortunately we were able to cheat and just disconnected the flap. Although that does present another problem is that I can no longer shut out bad smells, and in winter it can steam up inside, so have to open a window slightly to demist..
Posted 22 February 2018 - 05:35 PM
My wife says that is fair exchange!
She will hit you in the man jewellery and you can defrost the windscreen !!!!
Posted 22 February 2018 - 05:38 PM
Can't say that I find it an issue myself but would comment though that if its a diesel they don't warm up so fast as the thermal efficiency means less waste heat for heating. The climate control appears to monitor actual heater temp so doesn't pump heat in until it's heated up sufficiently. I do have heated seats though which i suppose help a bit.
It's a 1.4 multiair and the heating system is similar to her previous Bravo, which heated up like Beelzebubs naughty room . .
Posted 22 February 2018 - 05:39 PM
Only if she's naked too!
