Lambda Sensor Signal Wire
tomada3
hi have 3.3 grand voyager had fault code 0134 changed upstream o2 sensor reset codes came up again so had it diagnosed as break in signal wire from connecter to ecu
have tried without sucess to get pin out position of signal wire to connecter to ecu
have tested wires on my connecter
mine is 4 pin am i right in thinking 2 are negative and 2 are positive
tested all 4 pins only have 1 live
the pin next to it shows nothing its colour is green and black have traced wire through loom to ecu
can anyone confirm that this is the signal wire as dont want to bypass the wrong wire
my car is 53 reg
the sensor is genuine mopar sensor
thanks
have not split loom casing just assuming all wires are different colours and no two wires are same colour
to avoid bypassing wrong wire
thanks again
hi update on my car i have 2 sensors on my car upstream and downstream
the earth wires meet in the loom i had intermittent fault on the upstream earth resulting in error code p0134 p0171
had car fixed resulting in 5mpg round town improvement
if you have v6 just thought update you with result just in case someone out there has same problem
