P0403 Code
Madmax
I have the engine fault light on, not flashing just a steady light. The key dance tells me I have P1103, P0403 and p1685 codes. My mechanic said that his code reader was only showing P0402. Now I have checked the voltage on the pins that go to the EGR solenoid and this is only showing about 6 to 7 volts. Is this the correct voltage, have looked at stuff on you tube and they say 12 volts. But being a Chrysler who knows what voltage it should be. Any help will be appreciated.
