Central Locking Fuse
VoyagerAndrew
Hi ALL,
I read here somewhere that if the Central Locking stops working on Chrysler Grand Voyager Limited edition, 57 plate, the quick fix is to remove the central locking fuse for five minutes to reset the computer - on the cover of the fuse box, it says, "Disconnect Battery before Removing Fusebox Cover!" This seems to contradict the idea of simply removing the cover and lifting the fuse for five minutes - has anyone had direct experience of this before?
I think possibly what you are referring to is the IOD fuse, which is actually "Ignition Off Draw", which MIGHT help reset the Body Control Module if it's had a bit of a hiccup with various things.
But if I have read that warning I can't remember, and have clearly chosen to ignore its advice  :D  :D
