Voyager Key Fob Reactivation
DavidRyder
Found this tip on Honest John and it worked for me. Make sure the fob battery is ok.
Remove the IOD fuse between the battery and the ignition, marked. IGN -BAT in the fuse box under the bonnet. Replace it after ten seconds. Put the key in the ignition without turning it. Some dash lights may flash or they may not. That’s it. Try the fob.
Hi there, I tried the method that you advised, and unfortunately, it did not work. I followed every step you mentioned did not turn the ignition, but the key in no lights are flashing nothing was happening, turned ignition still nothing and then started the car and then so on... But I am stuck as it's a nightmare when you have to lock all your doors manually; I don't understand what needs to be done... Is there anything else, or do you know anyone else that had this problem
