Voyager Key Fob Reactivation
DavidRyder
Found this tip on Honest John and it worked for me. Make sure the fob battery is ok.
Remove the IOD fuse between the battery and the ignition, marked. IGN -BAT in the fuse box under the bonnet. Replace it after ten seconds. Put the key in the ignition without turning it. Some dash lights may flash or they may not. That’s it. Try the fob.
