The Dreaded 1130 Code 2007 2,8 Voyager
ontheroad
Hi all,
         as anyone ever found out the cure for the dreaded cutout and the 1130 code when kick down throttle is used on the voyager 2,8 2007 auto,roll to the side turn off ignition and then it will start, will drive all day but when you use heavy throttle the dreaded cut comes in, any info would be appreciated, i have done all the test and changed most of the sensors and pressure valves and checked for air in diesel lines , all seals changed on diesel filter housing, this is the one with the primer up front
cheers keith
