2005 Grand Voyager 2.8 Engine Light
dave62pb
Advise needed my GV has just failed MOT on engine light lit, doing the key dance it shows P 2120 throttle position sensor
The car runs fine with no cutting out or flat spots, anyway i replaced the pedal assembly with a tested used one as i could not find a new one
it is still the same with the light on, I spoke to somebody who had the same problem theirs was the MAP sensor so i replaced that with a new unit
the light is still on , where do i go from here ?
Regards
Dave
This question interests me. I've also got the check engine light,due to a boost code but I can live with it and the car still runs.
What if i were to remove the bulb or black-out the light on the cluster ?? Would it pass the MOT ?
Edited by frogland
