Suspension Clunking
Briscoe76
So the 300c Saga continues lol.
Over the past couple of months I've had a clunking from the front suspension progressively getting worse and worse. I can only describe the noise as something similar to when you knock the skittles down in ten pin bowling. Its a loud THUD, that can be felt through the car floor on both sides.
Having read through the forums of people spending hundreds of pounds on replacing this, and replacing that, I found a post where someone had replaced the anti roll bar bushes for "a couple of dollars" and the problem was cured.
So always wanting to start cheap and work up, i bought new bushes from that excellent online shop www.custom300cshop.co.uk for about £20 (i think) and i've just had them fitted. It literally took 20 minutes to fit them, and hey presto the car is silent again!!!!!
I can highly recomment this first of all, before trying more expensive fixes!
Cheers
Matt.
