Egr Valve Leaking 2.8Crd Grand Voyager 2006 Auto
ianbarber
Hi Can anyone help? my car only has 37,000miles from new; Recently I foolishly ran low on Diesel and as it was parked on a slope I ran it dry trying to start it; Subsequently having replaced the fuel filter I am experiencing great difficulty getting it started from cold; Once its going it drives as normal with no management lights showing; It has stalled on me a dozen times now at very low speed and rev's   I took it to a specialist in diesel engines and he tells me the EGR valve is leaking; Can this be the problem?  BTW for the longest time I have heard a very quiet but high pitched whistle when driving and until about 5 minutes once stopped; is this a Chrysler main agent job or can any decent local garage replace it?
thanks
ian
The test
- pump the hand primer pump until it is hard - does it start now ?
 http://www.lcool.org/technical/120_series/fuel_filter/filter2a.jpg
- if it starts after hand priming, its a leak in the LP fuel side
- air leaks in and the fuel lesks back to your tank
- eliminate 'leakback' first
- the 'spin~on' fuel filter is not tight enough
- the 'spin~on' water trap is not tight enough
- tighten them up !
- could be dozens of things including leakback
- hand primer is centre of engine area , take off the plaggi cover you will see it
- pump it, does it get hard in 3-5 pumps ?
- does the car start ok when its hand pumped ?
Best of luck !
