Delta Lancia Badging
Nello
I bought my Delta as a Fiat group enthusiast and have bought a replacement Lancia front Grill along with rear badge. The alloy centres and other badging will follow!
Replaced the rear easily enough - heat up the badge with a hair dryer then slide some string along to break up the adhesive. Roll off the excess with you thumb then remove anything left with sticky stuff remover. I just need to work out how to remove the front grill. There are 6 T30 Torx Star head screws along the top edge.
I think there is a fixing inside each front wheel arch to remove then a series of screws underneath the front edge under the car and the whole bumper should hopefully come off. Will confirm once I've done mine! The Grill itself is then held on to the bumper panel by 10 clips on the grill back that push on.
Edited by Nello
