2010 Grand Voyager 3Rd Row Seats Stuck
Daiben
My Grand Voyager 3rd row seats have stuck in the folded position, i.e. they are not in the normal position or stowed. I have taken it to my local garage and the mechanic said that the control unit is saying that the incorrect voltage is going to the seat motor however when he checked the voltage at the seats it was correct.
He has suggested I take it to a Chrysler Specialist to sort it out, but I have just found out (to my horror) that  Fiat have pulled the plug on Chrysler in the UK!
I am after 3 bits of advice really.
1. Does anybody know how to solve this problem?
2.The nearest Chrysler specialist to me, (I'm situated in Mid Wales)
3. Is there a way to manually shift the seats?
Wishing you all a merry Christmas
Hi
I have had the same problem. There is a dealer update for the electric sensors that can resolve some strange behaviour in the seat. If its totally stuck and all the electrics work and the motor is trying to move the seat i would bet that its the gear that is stuck.
Remove the seat with four bolts and tip it over. Remove the back cover on the left hand side you will see the motor fitted to the gear. Remove the gear and check if its loose. If it is, place a socket on the center bolt and hammer on it. When you have it loose, check for any dirt or sponge in the gear. Put some grease on it. You should now be able to turn the gear over by hand. Refit and it should now work.
