Dipped Head Lights Issue On Chrysler 300C
Madmel55
Hi I have a problem with my dipped HID beam (both sides) on my Chrysler 300c in that they start in the normal position then in about 2 to 10 minutes they drop very low. I have changed the bulbs, Ballasts, HID controller, has anybody got any other suggestions as to what could be causing this please.
Madmel55
...only assumtions:
Because they both do it, it is not at the end of the circuit, ie motors.
I bet they come with self levelling (or auto levelling).
I would look for the module that controls that, has nothing to do with the ballast and/or lamps, it is a module that I assume it works with mercury and so when you have full car (passengers and stuff in the boot) it will drop the angle down to a certain degree so the lights won't affect the incoming drivers.
I personally don't have one and not familiar with the model (even though I wish I buy one...is just never the right time) but follow this lnik and see if you get it.
You will have two sensors that will send info to a module, one of the three is faulty.
http://www.300cforums.com/forums/uk-europe-regional-forum/115273-hid-auto-leveling-module-question.html#/topics/115273
Hope it helps.
