Faulty Reversing Camera, Just A Black Screen
casper171072
The revesring camera on my 2009 Grand Voyager has gone faulty.  When I select reverse the screen just goes black but still shows the message at the bottom of the screen to check your surroundings.  I've checked the fuse (M34) which is fine.  Anyone any ideas
I see you can get reverse cameras off ebay for next to nothing now so i could replace it but not sure if it is actually the camera or not.
Hi, somewhere behind the bumper, or near the tail light, you will have the connections.
One is either, the color vary from manufacturer, but one of them is the supply, check if 12v comes to that end, if it does is faulty for sure.
Also do you have the reverse light coming on?
