Follow us on...
Fog Light Rewire
  • Please log in to reply
7 replies to this topic
#1 rustybullet
rustybullet
    L Plates
  • Members
  • Pip
  • 4 posts
  • LocationSA
Posted 25 August 2017 - 06:50 AM
Hi
Just bought a used 2001 Chrysler Neon 2.0LX
She's a real beaut'!
However the Front Fog Lights do not work.
I have opened up the MFS and the switch inside is damaged beyond repair
so I would like to go the Rewire route.
I found a few rewire instructables on the net but they are for American cars
so I do not have any wires in my fuse #19 in the Dash fuse box.
I would like to do a similar Rewire adding in a relay but I need some assistance please.
( I wouls like the Fogs to come on with the Park Lights and STAY ON with LOW & High Beams)
I know I must use a relay switch and I know pretty much how to connect it (thanks to the schematics on the net) but where do I get the "Front Fog Light" wires from to connect to the relay?
They are missing in the Dash Fusebox but there is a fuse under the hood labeled
"FOG BUX" (not sure if that is the correct one?)
I gather then that I must connect the "input" from a splice on the Park Lights wire at the PDC, connect it to the relay along with the Factory Fog light wire (this would obviously supply power to the Fog Lights) as well as a 12v Fused live and then a ground. So the switch side would be from the Park Lights, and my Fogs should turn on with my parks?
If that is correct, would there be any way to get my Dash Fog Light Indicator to turn on as well?
Would this work system?
I would really appreciate some expert advice!
Many thanks!
#2 mikebh8
mikebh8
    Jack of all trades...still learning
  • Members
  • PipPipPipPip
  • 595 posts
  • Locationdorset
Posted 29 August 2017 - 07:19 PM
Hi, not an expert but if you want to know how I do it, and done it to few cars, here is the following:
Get a 12volt ACC supply to each side ( or a bridge from one side to the other this way you only get one supply to them and you only use one relay)
Use two relays, one for each side (I usually fit them inside the head light), use the low beam lights as a power to the relays(I would put them on the low beam but if you wish you can use the day lights), wiring them in parallel with the low beam light bulb should do the trick.
If you get power from the fuse box, fit a fuse at max 30 cm away from the fuse box, this way whatever circuit you use is protected in case of a fault on your added circuit.
You could get the 12v supply directly from the battery, I would go for a 10 amp fuse, same max 30cm from the battery.
Unfortunately to get the front fog light on on the dash you need to use most of the original circuit....
Edited by mikebh8, 29 August 2017 - 07:28 PM.
#3 rustybullet
rustybullet
    L Plates
  • Members
  • Pip
  • 4 posts
  • LocationSA
Posted 06 September 2017 - 06:50 AM
Hi Mike
I am going the route you suggested.
I believe it is the best option.
Thanks very much!
#4 rustybullet
rustybullet
    L Plates
  • Members
  • Pip
  • 4 posts
  • LocationSA
Posted 06 September 2017 - 06:52 AM
Are the Neon keys are easily cloned?
#5 mikebh8
mikebh8
  • Members
  • PipPipPipPip
  • 595 posts
  • Locationdorset
Posted 07 September 2017 - 07:26 AM
On my autodata does not say anything on the "key programming" section, and I checked all years and models under neon section.
 This let me believe the only way is with a key programming software.
#6 rustybullet
rustybullet
    L Plates
  • Members
  • Pip
  • 4 posts
  • LocationSA
Posted 12 September 2017 - 09:53 AM
Hi Mike
I found this info on self programming.
http://www.keyfobpro...ey-programming/
Do you perhaps know what ID46 chip I need?
I believe there are 2x types. "Original" and "Factory Default"
(To quote from Chinese seller)
#7 Chrysl3r
Chrysl3r
    L Plates
  • Members
  • Pip
  • 7 posts
  • LocationTorquay
Posted 31 January 2018 - 04:43 AM
I think I've also seen those options-- "Original" and "Factory Default"
#8 Andnwend
Andnwend
    L Plates
  • Members
  • Pip
  • 2 posts
  • LocationUk
Posted 10 July 2021 - 07:41 AM
Hi there, we have a Chrysler neon Lx, she is nearly 19 and looking for driverside fog light as the glass has broken. If anyone knows how to repair the glass would be great or knows where we can find a replacement fog light. She is dew her mot in a few months. We would love to keep her on the road,such a wonderful car.
