Updating A Sat Nav Unit
KevR
I have a 2007 300c touring ,I would like to update the sat nav 6 disc cd unit to something with bluetooth and updated nav . Can anyone suggest what the old unit can be replaced with and is it plug and play or does it need professionally fitted
Cheers
The unit can be replaced by pretty much any make of the same size but remember that if a 'Boston' unit is fitted already then the amp will probably need to be disconnected from the system as they tend not to be compatible with I-pods and the like. Kenwood - Pioneer etcetera will all work or there is a conversion available that replaces the unit with an I-pad but not sure who does it, if anybody, in the UK! You may need further wiring harnesses to allow connection.
