Cd/radio Not Coming On After Jump Start
Gerschamps
I have a 63 plate upsilon that didn't start the other day for sum reason unknown but started when it got a jump start and has had no problem since except on the day it got a jump start my radio is off and can't find the fuse to check it any help would be grateful thanks
Hi
Take it when you say radio it's the central display that's failed? Does the interior light and 12v power socket still work it's on the same circuit. Have you checked all the fuse boxes? The display unit is separately fused in the rear of it you have to remove it to check the fuse. Failing that it's the BCM.
