No Fault Codes But Car Wont Rev Over 1500Rpm In Drive
hotrod1958
Is it the same car as previous posted?
You topped up the oil...It didn't come back to life?
Try removing the bottom bolt, from the gearbox, make sure you have a container for the oil that will come out. It is magnetic, if you have metal residue on it it means the fault is in the gearbox itself due to lack of oil.
