Rust Area On 2002 Grand Voyager
muso58
Hi folks
im considering buying a grand voyager with 150000  miles on clock.Can anyone give me info  on what i need to look for
.Im particularly interested in rust area ,as last mot listed corrosion on front chassis as an advisory .Any  other points would be greatly appreciated .Its very cheap  but could work out the opposite  i guess.
Cheers for reading
Hello there, I have just purchased my 2nd Voyager having first purchased a wreck to do up in 2015. I have only seen this post today so apologies if my reply is no use or too late. My 1st Voyager was a 2001 Grand 2.5 CRD. This had rust quite badly on the sills. From what I have seen this is quite a common problem. Obviously cutting out and welding in a new piece is best if it's bad. If caught in time I would clean up and treat with a rust treatment such as KRust and paint over with a sealant.
Both my 1st and 2nd Voyagers both 2.5 CRD Grand also have had advisories for corrosion on the brake hoses. If only slight, clean, treat and grease is my recommendation.
Anyway hope all went well.
Regards
Scott
